hth999
Hello to all:
I have posted several threads, and many have been very helpful to a newbie like me. So here goes:
Example: When I am listening to say Scan List 1 ( Pinellas CTY P25 ) for say 1 hour, and want to switch to a different Scan List, say Scan List 2 ( Fire Dept P25 ) I understand how to do this, but I think my 1095 might have strange behaviour. Once I switch the scan list it takes sometimes 5-7 to start to pick up the P25 objects in the list. It's usually about 2-3 minutes, but never right away. The LCD screen has the name of the scan list and the " T " is active, so why does it not start to pick up right away. Anything wrong?
Have others experienced this? My signals are very strong. I do have 6 multi sites programmed.
I also have a WS1080, with the same Scan Lists, and it never takes 5-7 minutes to start to pick up or get " hits". The WS1080 is usually about 1-2 minutes.
Once the 1095 picks up 1 "hit" it's good to go. Then it rapidly picks up the other P25 objects in the list and works normally.
Does this have something to do with the DSPLevelAdapt?
Both the 1095 and 1080 are at default for DSPLevelAdapt. Any information would be helpful.
Thank you!
Thank you!
