The RadioReference.com Forums
-   Whistler Scanners (https://forums.radioreference.com/whistler-scanners/)
-   -   DMR Programming (https://forums.radioreference.com/whistler-scanners/334139-dmr-programming.html)
Forts 05-31-2016 4:23 PM
DMR Programming
Well, I took a best guess approach to programming in a local conventional DMR channel. Here's what I did, and my results..
- Went to the Trunked Systems tab, hit New System
- Set the name to DMR Test and selected DMR as the system type
- Under Site Details, for site 1 I gave it a name and set the frequency and color code in the site frequencies box
- Under the Talkgroup Details tab, I entered the talkgroup ID and assigned it an alpha tag and scan list
Aaaaand I think that was it! I updated the programming on the radio and enabled only that scanlist and sure enough, it was talking away... and it sounds EXCELLENT!
Seems like a convoluted way to do a conventional system though. Not sure why you can't just enter your frequency, select DMR as the channel type (instead of FM/NFM etc). Assign CC, timeslot and talkgroup and away you go. The way it is now doing it via a pseudo trunked setup... how do I differentiate between talkgroup 100 on TS1 vs talkgroup 100 on TS2? A fire dept local to me uses this exact setup. OPS 1 is TG100 on TS1, OPS2 is TG100 on TS2.
Great start though, thanks to all involved at Whistler!!
DonS 05-31-2016 4:36 PM
That's part of Wendy's "additional DMR feature enhancements are in process and will be available shortly. Stay tuned!".
There will be support for "conventional DMR", where a conventional channel object has a frequency and, if desired, slot and color code. In your case, you'd create two CONV objects, same frequency, different slots.
Forts 05-31-2016 4:37 PM
Good to know, thanks very much Don. I'm super impressed with the audio quality so far, it sounds very very nice.
radionut44 05-31-2016 5:33 PM
Is there going to be an update for the GRE PSR800 version of the radio?
Forts 05-31-2016 5:37 PM
I would try asking in one of the other general DMR update threads, not a programming specific one.
scannerman200 05-31-2016 5:47 PM
What if all it shows in the database is 155.235, dmr and a color code and NO talk group IDs? How would I enter this?
DonS 05-31-2016 5:53 PM
Create a DMR trunked system
In the first (default) site, add that frequency
Set that frequency's "DMR CC" field to the value listed
Create a "Wildcard" talkgroup
You should then hear any DMR traffic on that frequency as long as the color code matches what you programmed.
(This is how I listen to local a DMR-MARC repeater, where all I care about are frequency and color code.)
scannerman200 05-31-2016 6:19 PM
Can I leave the color code to any?
DonS 05-31-2016 6:24 PM
You can, but if you know that what you're trying to monitor uses a specific color code, you should probably enter it. Otherwise, there's a chance that you'll hear other, nearby DMR repeaters that use the same frequency (but a different color code).
In this case, you can think of color code as CTCSS or DCS.
scannerman200 05-31-2016 7:16 PM
What should the DSP adapt be on a VHF DMR system?
Forts 05-31-2016 7:27 PM
DSP adapt?
Sent from my SM-N9005 using Tapatalk
scannerman200 05-31-2016 7:53 PM
The DSP adapt setting, the default is 64 I believe on the WS-1095. Should I lower it for the DMR VHF systems?
scannerman200 05-31-2016 8:19 PM
Thanks for the replies. The only other question I have is if you do a limit or service search, will DMR frequencies be received?
KI6AOK 05-31-2016 8:44 PM
As I discovered, the answer is no, not yet.
KI6AOK 05-31-2016 8:47 PM
Has anyone had any luck with a Cap+ system yet? I would appreciate any tips, because I'm striking out here trying to listen to the San Diego Zoo Safari Park.
N8IAA 05-31-2016 11:58 PM
KI6AOK, I have a Con + near where I live. Had no problem loading in the 1088 and for the first time in over four years, was able to monitor that county.
My mistake, didn't see that you were referencing a Cap +. Don't have any near me. Sorry
Larry
n2pqq 06-01-2016 1:11 AM
Confused: I tried the above but when I creat a site it says the site name I created
but then under sub type it reverts to p25 auto.
I am trying to use the drm frequencies located in Sussex county New jersey
Vernon
Frequency License Type Tone Alpha Tag Description Mode Tag
477.03750 WQGN627 RM 8 CC
192201 TG
1 SL Vernon FD 1 Fire 1 DMR Fire-Talk
192202 TG
2 SL Vernon EMS 1 EMS 1 DMR EMS-Tac
477.06250 WQGN627 RM 8 CC
192201 TG
1 SL Vernon FD 2 Fire 2 DMR Fire-Talk
192202 TG
2 SL Vernon EMS 2 EMS 2 DMR EMS-Tac
http://www.radioreference.com/apps/d...1789#cid-23827
Please Help .
troymail 06-01-2016 6:12 AM
Yes - I simply imported/programmed the same as other DMR systems in my area. Are you in the coverage range of the system?
Forts 06-01-2016 7:36 AM
Just ignore it. Mine says P25 Auto as well.
KI6AOK 06-01-2016 8:47 AM
Thanks for the reply. Yes, I'm within range and have listened to the system on a CS750. I'll reprogram and give it another shot.
