Howdy,
Other than the micro SD card that came with your scanner, I should appreciate it if you post micro SD cards that are confirmed to work with a Whistler scanner. Links to purchase would be awesome too.
I am trying a Kingston micro SDHC, Class 10, 32 GB. It's giving me error 3-01. I know this SD card is good -- it works fine in a dashcam that is much more demanding. I've formatted it a couple different ways, read other threads, etc. Before I start clearing and reformatting a ton of cards (all of which will be 32 GB or more), I'd like to be more informed. Likely, I'll just buy one which someone else can attest to.
Does anyone know of published specs for what types, sizes, and makes of micro SD cards are supported with these scanners?
Also, where can one find what the error codes mean? The guide says look online in the FAQ, and the FAQ has just one entry at the very bottom regarding getting an error code (which, according to that, all errors are caused by a corrupted SD card...).
From experience, code 3-00 is for no SD card and 3-01 has something to do with it not liking the SD card (but I'm not sure what it's looking for to throw the 3-01 error).
Note, there is a similar old thread that didn't pick up much steam, related to just the 1095 http://forums.radioreference.com/whistler-scanners/316612-what-sd-card-you-using-thread.html. I don't think it matters which newer Whistler scanner handheld model you have (mine is 1080). I guess the mobile models might use big SD cards instead of micro SD. To be sure, list which models the card worked with. Extra :lol: if you post the boot up time.
I'd prefer to find one of at least 4 GB since I record a lot.
Thanks,
Justin
Thanks,
Justin
