The inverted 'S' icon means that RF squelch opened, the scanner is expecting data, but no data has been received. It applies to DMR and LTR systems. It was intended to tell the user that he needs to adjust the squelch; you want to minimize the time you see the inverted 'S' icon.
In the case of DMR:
- Tune to frequency
- Wait for RF squelch
- Turn on inverted 'S' icon
- Wait for DMR sync. If timeout, start over with new frequency.
- Wait for DMR data. If timeout, start over with new frequency
- Turn on inverted 'T' icon
- Decode DMR data until 1) interesting voice traffic found, 2) DMR sync lost, or 3) dwell time expires. If (2) or (3), start over with new frequency.
The time in "Wait for DMR sync" is non-zero. If the scanner is waiting for DMR sync merely because the user turned the squelch knob fully counterclockwise (and not because it's actually an active DMR frequency), the scanner is spending time waiting for something that will never appear - time that could be spent checking other frequencies.
If you have 10 frequencies programmed, the scanner is currently on #2, and interesting voice traffic appears on #1, you have to wait for the scanner to go through the timeouts on frequencies #2-#10 before it will get back around to #1.
If you only have one frequency programmed in a DMR system and that system is the only thing you're scanning, then turning the squelch knob fully counterclockwise (so that you always see the inverted 'S' icon) is benign. It may actually help, since the scanner will be "camped" on that one frequency for a larger percentage of the time.
