  #121 (permalink)
Old 05-07-2017, 4:28 AM
ADC gain and DSP level adapt settings.
/Ubbe
  #122 (permalink)
Old 05-08-2017, 10:24 AM
lanemls's Avatar
/Ubbe
Thanks. Still wondering what kind of settings (in dB's, DSP Level Adapt, etc) for Ideal reception, esp. on P25 systems....In NUMBERS, that is.
  #123 (permalink)
Old 05-08-2017, 10:27 AM
troymail's Avatar
For non-simulcast systems/sites, no adjustment should be necessary.
For simulcast systems/sites, if it helps making adjustments at all, there isn't going to be a "one size fits all". If there was, there would be no need to adjust.
Therefore, in this case,you just have to experiment.
Unication G5(UHF)
  #124 (permalink)
Old 05-08-2017, 12:35 PM
lanemls's Avatar
Thanks. By the way, do you remember the DSP default settings on the EZ Scan app?
  #125 (permalink)
Old 05-08-2017, 2:09 PM
troymail's Avatar
DSP default looks like 64 (I've never changed it)
Unication G5(UHF)
  #126 (permalink)
Old 05-08-2017, 3:45 PM
lanemls's Avatar
I'll try "50" for now, and "tweek it" if I need to. Thanks, again.
  #127 (permalink)
Old 05-10-2017, 9:31 AM
Default novice
Wendy - I'm a novice, that's why I purchased the TRX2. But, it won't pick up anything on the newer Columbus Ga system. I see the new info on Radio Reference, but don't see the software on their list for the TRX2 to download directly.
From your previous posts, what am I downloading from to the SD card?
Help!
Jimmy
  #128 (permalink)
Old 05-10-2017, 1:41 PM
03msc's Avatar
Help!
Jimmy
You use the EZScan software to update and add the system to the scanner (check for firmware and DSP updates for the scanner, too). The software comes on the SD card and is installed on your computer. It then will update from the RR db.
Mark • Arkansas • K D 5 B V X
Uniden and Whistler Scanners • Kenwood and Yaesu Radios
  #129 (permalink)
Old 05-23-2017, 9:12 PM
KA9EES's Avatar
Default I'm a Noob!
Just recieved my TRX-2 from HRO today. Saw one at the Hamvention. Had done a little research. Pulled the trigger yesterday. I have done all the updates. Including the database. Just perusing this forum I learned how to get it to quit updating the firmware. Have a lot to learn. It's scanning just fine. I just need narrow things a bit as it is scanning far more than I really need.
73,
Ed KA9EES
Fithian IL
  #130 (permalink)
Old 05-24-2017, 9:14 AM
KA9EES's Avatar
[QUOTE=Swipesy;2719554]I would not recommend doing what 03msc suggested doing with Scan Set 1. I consider Scan Set 1 to be sacred and should be left as the master scan set for all ScanLists. Let's review here.
If you become a heavy ScanSet user as I am then you disable Scan Set -1; create Scan Sets 2-20 and enable/disable the Scan sets that you want to listen to.=QUOTE]
As a new user I find this a very good idea. No to learn how to manipulate things in EZscan! Also need to learn how to quote too!
KA9EES
Fithian IL
  #131 (permalink)
Old 06-22-2017, 9:28 PM
Default trx charge current quite low.
My trx gets updated every week or two. I like the new features added to the software / firmware.
I have enabled charging in the trx1 but the measured charge current is only 50mA.
This means a 50 hour charge time for 2.5ah nimh batteries.
Can you comment on this? It seems very low but I deal with it by charging batteries outside the scanner, by taking off the back insert, pulling off the rubber cover, then sliding the battery cover off, and swapping to a fresh set of batteries. And if I can leave it plugged in all the time, so thats two days to top them off.
Thanks Chris
Originally Posted by WhistlerWendy View Post
I know several of you have received your TRX or will be soon. When you receive it, please be sure to install the PC App that comes on the SD card rather than just using an older version of the app already installed on your PC.
The older app will not recognize the TRX and will not install any updates that may be available for the TRX since the time it shipped from our factory and we want to make sure you have the latest and greatest updates!
Not to worry, the new version of the app will not over write anything that you already have and may use for your 1095/98 or 1080/88.
Be sure to install the new app and then update the CPU and DSP as you would normally install and update.
Thanks!
WW
  #132 (permalink)
Old 06-22-2017, 11:53 PM
Get a Panasonic BQ-CC17 (110v model, different model for 220v) charger....cheap external charger, can charge each cell independently, shuts off each slot when the specific cell is done charging. :-)
Paul
  #133 (permalink)
Old 06-24-2017, 5:35 AM
beischel's Avatar
Originally Posted by KC2RCU View Post
I love my TRX-2 however.on MARCS-ip it cuts off transmissions after about one syllable. Anybody have similar experience? Are there some settings I need to adjust? Any help will be appreciated. Thanks.
Yes, assuming that you have the latest software (EX Scan), under the Advanced Features tab, go to the Receive PCIF Options tab, change the value of DSP Level Adapt to 90. Try it that way. You can experiment with the value up or down to see what works best for you. But for me, I settled on 90 for Ohio MARCS.
Whistler Wendy and the Whistler Engineer at the Dayton Hamvention told me the new software was coming right after Hamvention and that people had success with better Simulcast reception with a value in the 90s.
As soon as the new software was released, I started experimenting and yup, they were right. It has REALLY helped.
Give it a try.
  #134 (permalink)
Old 06-24-2017, 10:01 AM
Originally Posted by bheisner View Post
Just wondering if it's possible to display "Connect Tone", "WACN", "Site number" and "Repeater number" for a Motorola TRS system on the TRX-1 / TRX-2?
My Whistler WS-1040 can display the following when searching frequencies:
For Type II SmartZone Systems:
SID:BC0A S01 / CT:76.76
For P25 Phase I & II Systems:
Sy:680 R001 S002 / N683 W:BEE00
Very handy info when identifying a unknown / unreported Motorola TRS.
I had asked this as a feature request from Whistler and got this response:
"Ok, it seems that way back when GRE made the PSR800 they decided to leave off the Analyze mode as the new model was designed to be easy to use and no “expert” area. The current SD card units don’t have the extra buttons that the older units had so it may not be able to add it.
John Nolan | Engineering Assistant| The Whistler Group, Inc
Office: 479-464-3520| Fax: 479-273-6012| Toll Free: 800-531-0004"
Wally Bloss, WB0BAV
HTTP//www.wallybloss.com
A Human
  #135 (permalink)
Old 07-06-2017, 10:16 PM
I just took delivery of TRX-2. For the EZ Scan software , I have a an old laptop running XP or a pc running Windows10. Which OS would be best for a newbe to work with? Will I have driver headaches with Windows 10? I assume EZ Scan works with both XP and W10. I am looking for the easiest OS to use to get started.
  #136 (permalink)
Old 07-08-2017, 8:03 AM
I use EZ Scan on a XP, W7 & W10 machine with no issues. I find the TRX2 very clunky and slow, programming is like using a program from the late 90s and the power up time is horrible.
I got it for my truck but im not sure if its going in, The BCD996P2 is so much faster and easier but no remote head.
Who makes a software with no fill up or fill down? I put 700 channels in but have to click every one of the 700 to turn on or off settings, The clipboard works ok but they don't let you define every column, Why not let you make a spread sheet with all the rows and columns and be able to use the clipboard to import it all????.. Again things oter programs have been doing for 10 years
Oh and the SD corrupts every 3rd time i program it...Not ideal..A few more years and they might catch up to Uniden
Advanced System Key Master
  #137 (permalink)
Old 07-08-2017, 8:26 AM
buddrousa's Avatar
In the EZSCAN software go to SCANLIST click on the 1st one in line HOLD THE SHIFT KEY and click the last one in line. Now all are highlighted and you can change all wit one click.
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP BCD536HPx2 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 Tk280 TK2180 MD380x4 NX5300 NX5200 Buddy
  #138 (permalink)
Old 07-08-2017, 8:45 AM
03msc's Avatar
As buddrousa explained, you can do that easily in EZScan.
Sounds like you just aren't familiar with the software (it's different than Sentinel, obviously...but let's not even get started on Sentinel's shortcomings...) so you pretend it is lacking and make it out to be stupid. Yet what you complained about isn't really an issue.
Yes, it's different and takes some getting used to. Nobody will argue that. But it works and there's a reason they call it "EZ Scan".
Oh, and I've imported that way before, too, in EZ Scan. It's nice and handy!
You get more flies with honey...
  #139 (permalink)
Old 08-14-2017, 10:23 PM
allandunn's Avatar
Default Using Your New TRX
[QUOTE=WhistlerWendy;2596813]I know several of you have received your TRX or will be soon. When you receive it, please be sure to install the PC App that comes on the SD card rather than just using an older version of the app already installed on your PC.
----snip---
I received in the mail today my TRX-1 which I purchased NEW on an eBay auction from an eBay reseller. S/N 0002084. Everything was in the original box which obviously had not been previously opened. I installed the new EZ Scan software on my WIN 10 laptop and changed the date and time upon booting up. But when I went to update the CPU via the EZ Scan, the message on the display at the end of the install said the radio rejected the update and to try again. When I tried to do that, the TRX-1 would not respond as the previous firmware was overwritten levaing the radio totally inoperable. I cannot even turn the unit off unless I remove a battery.
What are my options here? I did leave a message on the Whistler support site earlier today.
  #140 (permalink)
Old 08-15-2017, 3:34 PM
Welcome to the world of TRX 1 !!
