Like the title says, who likes their new whistler better than their Uniden?
For my use the TRX-2 is one step down because the lack of remote control that the BCD536HP has. If I could get remote control clients for my TRX-2 then it would be equal to my BCD536HP.
Way too early to tell yet. It will take a whole lot more testing on all the different types of modes to make the final judgment. But early observations have the TRX-2 winning in audio quality by a landslide. And I really like the display of ALL info without compromise. Plus it is much easier to see. Weak signal testing on my VHF P25 put the 536 ahead. The 536 picks up clear audio while the TRX-2 Donald Ducks about 50%. This is only on the weakest signal. However, the TRX-2 will pickup weaker signals, displaying NAC, before the 536 does anything. This is actually more valuable to me for searching out new stuff. My TRX-2 was purchased to be my major scan search tool, thus the reason I need to log everything on the audio index in the software. But the TRX-2 sounds so darn good that I would really like to do more listening with it.
One criticism on mode selection. I would prefer channels set to DIGITAL to decode ANY digital mode. And I would prefer channels set to ANALOG to decode everything. Having separate selections for digital modes puts up barriers that limit what the scanner can hear. I want to hear it all, but also want the option to exclude analog when frequencies have noise on them.
Phil
If your TRX2 Donald Ducks 50 percent,perhaps you need an External attenuator before your antenna input,the WHISTLER is very sensitive,and my PSR-600 needed one and after that it was a great scanner.Only if you are using an external antenna of course.
And if you are not perhaps you should consider a nice base scanner antenna.
Phil: Regarding mouse fart. Digital or analog? Frequency? Conv or TRS?
What settings? Seriously, it is too early to tell. I too have some Donald Ducking (DD), but far less on TRX-1 and 2 compared to WS1080. Again, the audio is really great. Do find that my 436 stops on more weak P25 than TRX-1 up at 800 MHz, but still very early in the game for meaningful comparisons.
I have nothing important to say except: Who can afford both???
I can afford all 4 436 536 trx-2 and might buy a trx-1 but that will only come if we get server and remote client software.
Steve, as I stated above, P25 VHF High Band (upper portion). The TRX-2 opens squelch sooner showing a NAC (that is a very good thing), but the 536 opens with clear audio before the TRX clears up. Mind you, I have dialed in my X36 scanners to optimal decode at a setting of MANUAL 9. I'm finding it difficult to nail down the optimum value for the TRX. Default settings were not as good as what I have it set to now, but further improvement might still be realized when I get a good set of frequent weak test signals to test with.
Phil
Is it safe to that all the comparisons were made with the latest firmware updates from both UPMAN and Whistler Wendy, especially when comparing DMR slot 1 and slot 2 as they affect the X36 and TRX 1 and 2?
Skip
I run the latest firmware on all. But I have NOT tested everything on the TRX-2. I did test conventional P25 on VHF, and conventional DMR on UHF. Both did very well. I need to program a whole lot more into the TRX-2 to test "all". But its a great scanner. You can't go wrong.
Phil
Dad?
