I'm very seriously considering abandoning my Uniden loyalty for a Whistler TRX-2. There's one hinging question. The IF/Discriminator Output Mode. Does this supply actual, true discriminator audio same as a tap would?
I have, and I'm aware of what it says. However, a manual is not the same as the experience of an owner. I'm slightly skeptical about words vs experience.
I'm also interested in the answer to that question. I'm not sure I can justify spending that much money on another radio unless it has some clear advantages over the 436HP in some areas.
My pro 668 discriminator if turned on it works just like a tapped scanner i use it often with dsd to hear dmr traffic. So the trx should be the same...
