NXDN Update Now Available!
WhistlerWendy
Northwest Arkansas
The NXDN Update promised before the end of the year is now available!
It is recommended that you update in this order:
1. Update PC App
2. Update CPU
3. Update DSP
4. Update Library
Happy Holidays and Happy Scanning Everyone!
MtnBiker2005
San Diego County, California
Search for frequencies authorized for NXDN voice use with this search tool.
http://www.digitalfrequencysearch.com/
Look in each state's Weekly FCC Grants for new NXDN licenses.
http://fccgrants.x10host.com/quick.htm
NXDN Information
http://wiki.radioreference.com/index.php/NXDN
http://wiki.radioreference.com/index.php/NEXEDGE
http://wiki.radioreference.com/index.php/IDAS
Whistler TRX-1 digital handheld scanner
http://wiki.radioreference.com/index.php/TRX-1
Whistler TRX-2 digital desktop/mobile scanner
http://wiki.radioreference.com/index.php/TRX-2
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
or look in the database - we have some there, too, although not quite as comprehensive as the tool Aggie put together (message below)
kruser
West St Louis County, MO
1. Update PC App
2. Update CPU
3. Update DSP
4. Update Library
I was emailed the links for the PC APP and the CPU update but not the DSP Update.
Where do you get the DSP Update from or do you simply use the PC App to download and install it?
I'm at work so don't have access to my TRX-2 yet but did download the two I was emailed about.
Thanks!
03msc
RF is RF
The Natural State
Thanks!
It's all done from within EZScan...then Check for updates...not sure why you would have been emailed a CPU update...scanner needs to be connected to the PC and then you run EZScan and let it check for what it needs...
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I haven't completed all the wiki changes needed, but hopefully if my questions in the other thread are answered, I can do this tonight.
I don't have these scanners, so any corrections are welcome...Mike
kruser
The emails for the PC APP and CPU Update were just links to the actual downloads.
Thanks for the clarification about the PC App doing the DSP update.
I get emails from Whistler whenever there are any scanner related updates.
The update email for the 1080/1098 came through a few minutes later.
03msc
RF is RF
The Natural State
Gotcha. Yeah, as long as you have EZScan you are good to go...just do the updates one at a time in the order listed in the first post as that is their recommended order of operations.
SCPD
QRT
Virginia
Thank you to all the hard workers at Whistler and may all their family have a MerryHappy holiday!
racingfan360
Can someone confirm which flavors of NXDN are decoded with this latest upgrade please:
- NXDN4800 (6.25khz)?
- NXDN9600 (12.5khz)?
- Conventional only or trunked too?
TIA
mrkelso
NNJ
why is it not detecting my cable for cpu or dap but finds everything else?
Ubbe
Stockholm, Sweden
Same problem here. And EZScan couldn't be upgraded, "couldn't write TRX-2.exe"
I uninstalled and installed file from whistlers website. After CPU upgrade the USB connection dropped.
Had to power off/on the scanner and then continue the upgrade.
/Ubbe
Ubbe
Stockholm, Sweden
The release note says:"The Mode column will accept a value of NXDN, NEXEDGE, IDAS, NXDN48, or NXDN96 as valid NXDN options."
But can't be right? I can only find one setting, NXDN, for conventional and NXDN(C) and (D) for trunked.
/Ubbe
oz1jua
Copenhagen
Error code conatact Whislter.
After update to new version TRX-2Install_3.0.0.480.exe and run all updates from new program today I got some problems.
When press Scan it scans fine. But When select menu and then select Scanlist for browse scanlist following error comes.
-Error Detected-
Please contact
Whistler Service
for assistance.
Code: 1-01
When select this before using scan it its OK.
W4KRR
Coconut Creek
TIA
I can confirm it works on a trunked NXDN4800 system locally. Can't confirm NXDN9600.
