TRX-1 display
safetypro79
Scanning since 1967
Anchorage-Alaska, Boise-Idaho, Salem-Oregon
I am a new owner of a TRX-1 but not new to the hobby or radios.
radio is not scanning my local P25 and Conv freqs they have been
My display reads:
Multi Dispatch
Channel psDr
NEW CONV
and nothing on rx. when I change to
when I turn the raion back on it revert t this display?
Ubbe
Stockholm, Sweden
The lists that the display show are the ones that are scanned. Check EZScan in advanced tab that you have choosen "Scan sets require scan lists to be enabled".
Could also be a bad SD card. Try and reformat the SD card in a PC using the SD Formatter program that you can download and let EZScan prepare and configure the card before using it in the scanner.
We are many that have received bad SD card from the start that creates many strange things with the scanner and are difficult to solve when you are starting as a beginner with a new scanner.
My SD card started to work after reformat but also other SD cards worked straight away.
/Ubbe
AggieCon
Texas
What did Whislter customer support say? Did you call them?
Also, this should help: Select
It's not specifically for the TRX-1, but the WS1080 and WS1088 are close enough in most ways that it will help. It's like the proper user guide Whistler meant to make but decided to save the money instead, relying on free customer support via others on Radio Reference.
