I am in Montgomery CO KS and one of the Trunk Systems here is Actions Communications. The type is NXDN NEXEDGE 9600. I programmed everything in using Arc500 but there aren't any frequencies showing up when I go to the TSYS under pgm on the radio for that trunk system. Also the type is set for MOT 800/900. If I read the RRR correctly it is showing NXDN NEXEDGE 9600 as the type but I am not seeing it is not an option when I go to the Action Comm trunk system (which the software programmed in) in the WS1040 scanner. Any help wound be much appreciated!
