  #61 (permalink)
Old 03-26-2017, 12:03 PM
Joseph11's Avatar
It beeps when you hit it but still shuts off if you continue to hold it down.
  #62 (permalink)
Old 03-26-2017, 1:07 PM
Ed6698's Avatar
Originally Posted by bheisner View Post
I just got the following response from Whistler:
"The handheld units should be shut off before removing USB power to prevent corruption to the SD card. It has always been like this and their have been no changes to the code for this function."
I'm shutting the unit off now before unplugging it just to be safe.
I did notice this update now requires you to hit the power button twice to shut it off (it beeps the first time).
That is a nice feature and I like it. There have been many times where I've bumped the power button by accident and the unit just shutdown. Now it gives you a warning.
This is in the owners manual. Same thing goes for plugging it in also, unit must be off before plugging in.
Also if your scanner would shut off from just bumping the power button, sounds like there is a issue with the power button. These scanner do not shut off unless the button is pressed and held down for a couple of seconds.
WS1080 WS1095 PSR500 PRO95 BC200XLT x2
  #63 (permalink)
Old 03-26-2017, 1:44 PM
03msc's Avatar
No, no change here either. You just hold the power button down, as always.
Mark Arkansas K D 5 B V X
Uniden and Whistler Scanners Kenwood and Yaesu Radios
  #64 (permalink)
Old 03-26-2017, 8:37 PM
Yes. But at least it warns you now.
BTW, I can now unplug the USB cable and the unit did not shut off this time. In fact, I tried it 3 times in a row and it stay one. My TRX-1 has always worked this way (from day one). The shut down issue just recently surfaced, I've been unplug it for months while like that.
  #65 (permalink)
Old 03-26-2017, 8:38 PM
The unit beeps now when you hit the power button, It did not do that before the most recent update.
  #66 (permalink)
Old 03-26-2017, 9:07 PM
03msc's Avatar
Yes it did. At least mine did and always has. Interesting that yours didn't.
  #67 (permalink)
Old 03-26-2017, 9:33 PM
K9DAK's Avatar
Ever since my BC100 back in 1984, the manuals have always said plug in, then turn on; turn off then unplug. Makes sense.
Cheers and 73 de Dave, K9DAK
PRO-51, PRO-92, PRO-106, PRO-197, TRX-1, HTX-202, FT-530, TH-F6A, FT-8000, FT-847
Don't worry, relax, have a homebrew...
  #68 (permalink)
Old 03-31-2017, 6:17 PM
firemast's Avatar
after the update my NXDN Ch i can Now only hear half the conversation like hear the cars and not the base is there any thing i can try to fix i tried adjusting the squelch and plating with the att and still the same
  #69 (permalink)
Old 04-05-2017, 9:56 PM
Default EZScan questions
Very new to EZScan and the TRX-1, trying to figure it all out.
I am missing a huge amount of traffic compared to my GRE-600 that is setting next to the TRX-1. Maybe wrongly, but I attribute it to the scanner taking too much time to scan back around to that talkgroup or conventional channel. The GRE actually has more programmed into it. Is there a way to speed up the scan? I noticed "blink time" settings, does that have to do with it?
I have conventionals and trunked systems both in the same scanlist, is this effecting performance?
How can I change the order of my conventional channels, or can I? I am used to WIN500 where you select and move them where you need to.
When I click the help tab and view help, nothing happens. I read where someone else was having the same issue but didn't see a fix.
The reception is poor too at times, seems to be very distorted/digital on our P25 system when the 600 is clear.
I apologize in advance for the newbie questions. Definitely not new to scanners/scanning but am to this model and software. It has kicked my butt and been very trying to say the least.
  #70 (permalink)
Old 04-06-2017, 9:24 AM
Daleb49's Avatar
I found this link in the internet about two weeks after getting my TRX-1 and it helped me a lot.
This user has several video's all with good information I felt.
I came from a GRE-500 using Win 500 and EZScan is different for sure.
Check this link out: https://www.youtube.com/playlist?lis...63QcRNVYQ1X2Ti
Dale
Pro106, PSR-500, TRX-1
