Hi everyone -
There is a just released update for the TRX1/2, 1080/88 and 1095/98.
The updates are on the server and will be on our website shortly.
***************PLEASE UPDATE THE PC APP FIRST****************
EZ SCAN RELEASE NOTES
WS-108x/WS109x:
Version 2.19 - March 17, 2017
•Corrected issue when adding an analog conventional channel from the scanlist tab where the settings for NXDN would be displayed when attempting to set the CTCSS/DCS/NAC values.
•Added filters to disable importing of frequencies that are outside of the scanner's frequency range.
•Corrected an issue with creating a new system during the import from the library process where encrypted channels were not being imported when the option to do so was enabled. This required changing how the app handled these settings internally which means that anytime the import options are changed and the OK button is selected on that screen, the selected options will be saved and used until changed.
•Updated all supported bandplans.
•Changed how the app handles entry of frequencies. Previously the app would verify a frequency to make sure it fit the scanner's bandplan and step size within that range. The app now will verify that the frequency is in the scanner's frequency range and then round off the entered frequency to the nearest frequency that matches the bandplan if necessary.
•Added the ability to sort the system listing on the Trunked Systems tab. This feature will sort the list by clicking on the column header. This action only changes the order that systems are displayed, it will not actually change the order of systems on disk.
•Updated informational message when checking for all updates.
•Corrected tab order and tab stops in the library import areas.
•Moved the Import and Clear buttons to the middle of the screens in the library import area.
TRX-1/TRX-2:
Version 3.4 - March 17, 2017
• Corrected issue when adding an analog conventional channel from the scanlist tab where the settings for NXDN would be displayed when attempting to set the CTCSS/DCS/NAC values.
• Added filters to disable importing of frequencies that are outside of the scanner's frequency range.
• Fixed an issue where the frequency rounding process in the UHF range was incorrectly rounding the entered frequency down 3.125KHz below the desired frequency.
CPU RELEASE NOTES
WS1080/88 v4.6:
* Changes to CAN and UK bandplans
* Bug fix in "update from library" when CONV objects have been deleted
* Add digital mode filtering to Limit Search (and Tune)
* Distinct tones when enabling/disabling scan lists in menus
* Zeromatic enhancements
* Add 'tune mode' to top Search menu
* Code size reductions
WS1088 only:
* Fixed problem with audio when entering Playback mode via Fn+6
* Fix garbage characters when key locked/unlocked message clears
* Add 'tune mode' via Fn+0
* Handling for unused Fn+[digit] combinations
WS1095/98 v3.7:
WS1098 only:
TRX-1 v5.3:
* Fixed problem with talkgroup and radio IDs in NXDN playback
* Handling for NXDN PROP_FORM SACCH messages
TRX-2 v4.4:
WS-108x/WS109x:
TRX-1/TRX-2:
CPU RELEASE NOTES
WS1080/88 v4.6:
WS1088 only:
WS1095/98 v3.7:
WS1098 only:
TRX-1 v5.3:
TRX-2 v4.4:
