Old 03-17-2017, 5:31 PM
WhistlerWendy's Avatar
Whistler Representative
Talking Scanner update 3/17/17
Hi everyone -
There is a just released update for the TRX1/2, 1080/88 and 1095/98.
The updates are on the server and will be on our website shortly.
***************PLEASE UPDATE THE PC APP FIRST****************
EZ SCAN RELEASE NOTES
WS-108x/WS109x:
Version 2.19 - March 17, 2017
•Corrected issue when adding an analog conventional channel from the scanlist tab where the settings for NXDN would be displayed when attempting to set the CTCSS/DCS/NAC values.
•Added filters to disable importing of frequencies that are outside of the scanner's frequency range.
•Corrected an issue with creating a new system during the import from the library process where encrypted channels were not being imported when the option to do so was enabled. This required changing how the app handled these settings internally which means that anytime the import options are changed and the OK button is selected on that screen, the selected options will be saved and used until changed.
•Updated all supported bandplans.
•Changed how the app handles entry of frequencies. Previously the app would verify a frequency to make sure it fit the scanner's bandplan and step size within that range. The app now will verify that the frequency is in the scanner's frequency range and then round off the entered frequency to the nearest frequency that matches the bandplan if necessary.
•Added the ability to sort the system listing on the Trunked Systems tab. This feature will sort the list by clicking on the column header. This action only changes the order that systems are displayed, it will not actually change the order of systems on disk.
•Updated informational message when checking for all updates.
•Corrected tab order and tab stops in the library import areas.
•Moved the Import and Clear buttons to the middle of the screens in the library import area.
TRX-1/TRX-2:
Version 3.4 - March 17, 2017
• Corrected issue when adding an analog conventional channel from the scanlist tab where the settings for NXDN would be displayed when attempting to set the CTCSS/DCS/NAC values.
• Added filters to disable importing of frequencies that are outside of the scanner's frequency range.
• Fixed an issue where the frequency rounding process in the UHF range was incorrectly rounding the entered frequency down 3.125KHz below the desired frequency.
CPU RELEASE NOTES
WS1080/88 v4.6:
* Changes to CAN and UK bandplans
* Bug fix in "update from library" when CONV objects have been deleted
* Add digital mode filtering to Limit Search (and Tune)
* Distinct tones when enabling/disabling scan lists in menus
* Zeromatic enhancements
* Add 'tune mode' to top Search menu
* Code size reductions
WS1088 only:
* Fixed problem with audio when entering Playback mode via Fn+6
* Fix garbage characters when key locked/unlocked message clears
* Add 'tune mode' via Fn+0
* Handling for unused Fn+[digit] combinations
WS1095/98 v3.7:
WS1098 only:
TRX-1 v5.3:
* Fixed problem with talkgroup and radio IDs in NXDN playback
* Handling for NXDN PROP_FORM SACCH messages
TRX-2 v4.4:
Old 03-17-2017, 5:36 PM
mancow's Avatar
Old 03-17-2017, 6:05 PM
I hope this works cause all I get is one or two words of of the nxdn frequency or none at all, and I hope my signal sweeper will work now cause it has never worked since I have had this scanner I think it might be defected.
Old 03-17-2017, 6:22 PM
wbswetnam's Avatar
Still no decoding of text aliases in NXDN mode?
Too much of a good thing can be wonderful. - Mae West
Old 03-17-2017, 6:35 PM
ecarvalho's Avatar
Sent from my iPhone using Tapatalk Pro
Icom IC-PCR1000 / BCD536HP / GRECOM PSR-800 / BCD996P2 / TRX-2 / Unication G4 & G5
Old 03-17-2017, 6:38 PM
Thanks for the bullets on update the PC application first. Last time my firmware update hosed up the scanner and had to use the firmware update utility to fix it.
Everything went smooth today.
Old 03-17-2017, 6:54 PM
wbswetnam's Avatar
Excellent. To make certain that the software updates first, I don't even connect the scanner until after the software update is complete.
Old 03-17-2017, 6:56 PM
N2MWE's Avatar
Thank you!
I've done my bid for king and country
Old 03-17-2017, 7:01 PM
Tattoooz's Avatar
Thanks for the quick heads up on the updates Wendy! All executed smoothly!
Sincerely,
Tattoooz
Whistler TRX-2
Taylor, MI
Old 03-17-2017, 7:14 PM
SOFA_KING's Avatar
Still no Access Control column for showing NAC and tone access codes on Audio recordings?
Phil
Old 03-17-2017, 7:27 PM
Joseph11's Avatar
Any chance of getting a tune menu option for WS1080 and WS1095 users? Or people using a WS1095 head on a TRX-2? Thanks.
Old 03-17-2017, 8:02 PM
buddrousa's Avatar
All updated with no problems thanks Don Wendy and the Whistler Crew.
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP BCD536HPx2 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 Tk280 TK2180 MD380x4 NX5300 NX5200 Buddy
Old 03-17-2017, 8:12 PM
K9DAK's Avatar
It's there:
WS1080/88 v4.6:
WS1095/98 v3.7:
TRX-2 v4.4:
Cheers and 73 de Dave, K9DAK
PRO-51, PRO-92, PRO-106, PRO-197, TRX-1, HTX-202, FT-530, TH-F6A, FT-8000, FT-847
Don't worry, relax, have a homebrew...
Old 03-17-2017, 8:15 PM
Joseph11's Avatar
Wow, I can't believe I missed that after reading through the original post. Thank you! And thank you to Whistler and Wendy! It's not really usable without a keypad, though. There's no way (as far as I can tell) to select the position of the number you want to change. You can just go up or down.
Old 03-17-2017, 9:20 PM
I am dead in the water since loading the software update... My computer isn't seeing the SD card...
Old 03-17-2017, 10:44 PM
kbod9633's Avatar
All updated no problems so far
Bob
BCD536HP, BCD436HP, BCD996XT, 2 TRX-1's , PRO-96
Old 03-17-2017, 11:14 PM
Did you reboot your pc?
Sent from my SAMSUNG-SM-G870A using Tapatalk
Old 03-17-2017, 11:16 PM
Exclamation
Originally Posted by WhistlerWendy View Post
CPU RELEASE NOTES
<snip>
WS1088 only:
They still seen to be handled weirdly.
For example while scanning [Fn] [7] acts just like you pressed 7 and toggles scanlist 7 on/off !!
I would expect to hear an error beep and no effect.
Old 03-17-2017, 11:58 PM
Same thing happened to me jmcdevittcaptain.
With scanner off and or no batteries in it. plug in you USB, you should hear an audible bing. Look in your (Start button- then computer there should be a list of a drive, (but not listed as Whistler make and model) just a G or H drive. It did not make any difference if I held menu down or not. It would not recognize anything as you said.
For some reason, I had lost my com port setting for my cable from the computer to scanner.
I had to go into my device manager on my computer and look at your com port list. your whistler scanner should be there and it will tell you the correct comport setting it is using. Mine was com port 13. Now with this com port knowledge, I forget exactly where. But the USB cable setting needed this correct com port setting number. I believe this error was seen in the device manager as a yellow check in your list of hardware. click there and it asked me for a correct com-port from a drop-down box, click your correct comport # and close out . (sorry now that I have mine set correctly I can not replicate this error fix better).
Once I made this correction my whistler scanner make and model # came up in my driver profile like it use to. The scanner started to respond and was able to move forward. Then I was able to reload from Whitler the new update 2.19.0.59exe file. Follow these steps and whla. your back in busines.
Hope this helps.
Old 03-18-2017, 12:20 AM
Unable to update PSR800/WS1080 from v4.5 to v4.6. I tried with Whistler's CPUUpdater_WS1080_U4.6.exe. Error - Please reboot on WS1080 screen. With Ez Scan could not read scanner. It updated from none (version) to v4.5 and operating fine.
Mudary
