Shortcut to deleting sites
troymail
Silent Key
Instead of deleting each site one at a time, is there a shortcut that I can use to delete several at once?
Not once programmed in EZ Scan from what I've seen.
I know it's not a great solution but I've found the easiest way sometimes is to delete the system and do a new import with only the sites of interest
afdscan
Central Indiana
Thank you, I'll probably end up doing that.
