mejnetguru
Stumbled on an odd (but minor) bug a while back, maybe someone can replicate it to confirm.
Easy to reproduce. Have NO scan lists enabled and then press WX to listen to weather mode, press again to go to Skywarn mode, scanner locks up with error 1 and will require pulling the battery to clear. To fix the problem just make sure a scan list is enabled, doesn't matter which one or even if there is anything in it. You just have to have a least one scan list enabled or you will error-lock entering Skywarn mode.
Occurs on both PSR-800 and TRX-1 (and I would presume their cousins).
