Won't work
wjnicosia
Need help have whistler ws1040 programmed using starrsoft win500 not one sound.programmed manually still nothing thanks wayne
03msc
RF is RF
The Natural State
Welcome to the forums! Provide us with a little bit of additional information - what system(s) did you program, etc., so someone can better help you make sure it is programmed properly.
wjnicosia
Whistler ws1040 won't receive
Programmed from radio reference project 25 phase 1 7 tsys 30 tgrp. tower is about 10 miles away.it's scanning but shows no signal strength.if I turn the squelch all the way down no static.
03msc
RF is RF
The Natural State
You won't hear static if programmed with a P25 system (digital) so that's not a concern if that is all you have programmed.
What system are you wanting to monitor?
wjnicosia
St bernard and plaqimines. Parish in louisiana.even tried limit search 771. To 774. Which all frequencies are in a d still nothing.
Redneck0410
Hutchinson, KS
Wayne-
I just recently received a Ws1040 and I noticed I had an issue similar to yours. I used PSREdit 500 to reset the scanners global settings back to factory and that cured my signal bar issue. Not sure if that's what you're describing.
-Shawn
Sent from my SM-G930F using Tapatalk
