  #41 (permalink)
Old 05-21-2017, 8:23 PM
Default Whistler upgrades for RS/GRE scanners
I talked to the Whistler people at Dayton (aka Xenia). They said this has been in the works for quite a while. If I understood correctly, the upgrade will also make the scanner eligible for service by Whistler for future possible problems.
  #42 (permalink)
Old 05-22-2017, 1:01 AM
Hi Wendy,
If I understand correctly, with a PRO 668, after sending it in for the upgrade, I would no longer use the RS software and use the Whistler EZ Scan from that point forward ?
It wasn't too clear on how we go about programming it from that point on.
Thanks,
R
  #43 (permalink)
Old 05-22-2017, 6:36 AM
KT4HX's Avatar
Originally Posted by R8000 View Post
Hi Wendy,
Thanks,
R
That is correct and Wendy confirmed as much on the first page of the thread. We would use EZ-Scan once the upgrade is done and no longer use I-Scan. In post #5 she said "Yes" in response to the question in post #2, which she clarified in posts #17 & 18. So you understand it correctly.
Alan
Scanners: BCD996p2 || PSR-600 || Pro-668 || Pro-651 // Shortwave: Drake R8A || Drake SW-4A || Tecsun PL-660
// FM: Onkyo T-4310R || Onkyo T-450RDS
  #44 (permalink)
Old 05-22-2017, 12:36 PM
  #45 (permalink)
Old 05-22-2017, 1:49 PM
minasha's Avatar
Hope Wendy can answer this simple question:
After doing the upgrade will my pro-668 be able to do future firmware upgrades written for the ws 1080?
  #46 (permalink)
Old 05-22-2017, 4:55 PM
DJ11DLN's Avatar
Yes.
If it looks stupid but it works...it ain't stupid.
  #47 (permalink)
Old 05-22-2017, 6:28 PM
Homeboys-Scanna's Avatar
Will the upgrade provide proper rest channel following / control channel trunktracking? Or will the scanner be only conventionally scanning through DMR trunking frequencies hoping to follow talk groups?
"Copy, 132 and Bush, cover's code 3."
  #48 (permalink)
Old 05-22-2017, 10:19 PM
With the exception of recording in very limited circumstances, I've found my PSR800 close to useless. Thanks to Whistler for improving and evolving this platform into what they've done with the 1088 & TRX-1. I'm very open to any offers they make to actually improve the existing 800's.
Thanks, Whistler!
73/Allen (N4JRI)
  #49 (permalink)
Old 05-22-2017, 11:16 PM
I'm glad that I kept my PSR-800.
  #50 (permalink)
Old 05-23-2017, 2:17 AM
KT4HX's Avatar
Obviously Wendy can respond for herself, but my understanding is since we would be using EZ-Scan to run updates rather than I-Scan, that we would indeed be pulling down future updates designed for the WS-1080 platform. I can't imagine they would write separate updates for the Pro-18, Pro-668 and Pro-800 after doing the upgrade in their shop. It would be so much simpler to convert them to the WS-1080 platform to accept future updates just the same as a native WS-1080. Simply put - one model, one update.
Alan
  #51 (permalink)
Old 05-23-2017, 8:20 AM
Default Legacy Upgrade - EZScan update?
I currently use the EZScan for my PSR800. Once my hardware is upgraded, will I continue to use the existing EZScan for PSR800 software or will that also be upgraded to communicate with the upgraded hardware?
  #52 (permalink)
Old 05-23-2017, 8:41 AM
Signal-Zero's Avatar
Why do people ask the same question that has already been answered. Basically they are turning your PSR-800 into a WS-1080. You will use the EZ-Scan version for the WS-1080 after that.
"We celebrate our independence from the Government, not our dependence on it."
  #53 (permalink)
Old 05-23-2017, 6:34 PM
If they're turning into a WS-1080, then hopefully it won't freeze the audio on my PSR-800 like my last attempt did.
  #54 (permalink)
Old 05-24-2017, 1:14 PM
Quick question on the PRO 668 upgrade program. I have three brand new PRO 668's, not a mark on them.
Would I receive the same units back that I sent in? I do not want to send in my new units and get another owners units in return? Also would it be wise to send in all three units at once or send in one at a time? Thanks.
This is a great program to keep customers and win over more.
  #55 (permalink)
Old 05-24-2017, 1:16 PM
milcom_chaser's Avatar
That's a phone call to Whistler kind of question
  #56 (permalink)
Old 05-24-2017, 1:22 PM
WhistlerWendy's Avatar
Whistler Representative
Not to worry! Every unit sent in will be accompanied by a form you will fill out with your information including the Serial number from your unit. This form will be provided to you when you purchase the update.
You will receive your unit back.
  #57 (permalink)
Old 05-24-2017, 3:00 PM
Default New Legacy Scanner Upgrade Program
Wendy, could you inquire about purchasing a 1088 front assembly, so we can upgrade our 1080's to the keypad version (1088). Can do the upgrade myself, or have Whistler do it in-house.
Thank you
  #58 (permalink)
Old 05-24-2017, 3:11 PM
Wonder if there will be any upgrades for the WS-1065?
The radio sure is a great scanner radio with excellent P25 decode.
  #59 (permalink)
Old 05-24-2017, 3:38 PM
I have a similar question, since I will be sending PRO 668s for the up grade any chance the front panel could be replaced to the key pad version (WS1088)?
  #60 (permalink)
Old 05-24-2017, 6:13 PM
mrkelso's Avatar
Where do i send it and to whom shall i make out the check?
Tags
trojan malicious code, whistler scanner
