- Joined
- Jul 7, 2010
- Messages
- 588
Is anyone else having an issue when unplugging the SD card from the scanner and plugging it into your laptop, using EZ-Scan to listen to the audio recording files, I would say more than half the time when listening, the recording audio skips every other second, sometimes not being able to make out hat the recording audio was said. It also does it with the scanner plugged into the USB port on the computer as well but the transfer rate is just so painfully SLOW I just take out the SD card and plug it into my laptop for any changes I need to make and it's done in 5 seconds. Is anyone else having this issue with the recordings using EZ-Scan skipping every other second?? Thanks!
••David
••David
