New control demo
wbswetnam
DMR-istan
I've been experimenting with the new control demo's logging feature on my WS 1095. I have noticed that for P25 transmissions, it correctly logs the talk group, but for DMR transmissions, it does not. It records the slot and color, but not the talk group - instead, in the column for talk group, it merely writes the frequency. Is this intentional?
scosgt
Does it work with the prior firmwares or only with the paid update?
The prior control demo worked with all the 800/Pro-18 line
g6fgy
London, UK
Whilst its not necessarily of help at the time of receiving, all the details (TG. Slot. CC etc) are logged in the appropriate .csv file if logging to file is enabled.
Wackyracer
Only useful data is the date and time most everything else is a ZERO, I 'm using it with a trx-2.
g6fgy
London, UK
Due to the way the forum formats text, the item below doesn't display properly, but is a typical entry from one of my .csv files:
TYPE COMP_DATE COMP_TIME SCAN_DATE SCAN_TIME ALPHATAG SYSTEM INFO OBJECT_ID TGID1 TGID2 RID1 RID2 SITE TSYS_ID OTHER_TEXT FREQ1 FREQ2 SQ_MODE SQ_VALUE TSYS_TYPE
SRCH 07/01/2017 08:42:02 06/01/2017 08:42:33 DMR 453.900000 0 161 16027 16027 -1 0 Slot:2 Color:10 453900000 0 None Motorola
The frequency is 453.90000 followed by a zero. The next number is the TG number (TGID1)
You do need to have the latest firmware update installed. Above taken from TRX-2 also.
TAbirdman
MO
Guys, whistler wendy has said a few times that this is a demo software so 3rd party developers can create a program. I don't see whistler spending much time on this.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Wackyracer
I don't get any of that except DATE AND TIME with my trx 2, windows 7 pro 64bit and excel for MS office 2013.
