TRX-1 & 2 on Linux
A query for the coding experts - Linux (Mint/Ubuntu) sees the SDcard in the radio as a removable drive, which is fine, but there's no driver for the on-board modem when using EZscan or the Democontrol software - which appears to run under Wine, until you need to enter a com port.
The product & device ID are shown when examining the USB connections (2a59:0011) but there's no CDC-ACM driver associated with it. I note that some one has written an API (https://forums.radioreference.com/whistler-scanners/349122-trx-2-maybe-trx-1-cross-platform-api.html) which looks as though it'll do the job, but I don't have the coding skills to know whether the source code (as a .h file) can be used to compile a suitable driver, let alone how to do it.
So my question is, has anyone successfully written a suitable Linux driver for use when the radio is in modem mode (I.E EZscan etc) & if so, would they be prepared to share?
I run Linux as a base system and it's a right PIA to keep opening a virtual windows machine every time I want to do something on the scanner
Eric - G6FGY
Eric - G6FGY
