craneoperator99
- Joined
- Jul 24, 2015
- Messages
- 224
Hi everyone,
I have a few questions about the Whistler WS1088. Please forgive me if these questions are commonly asked questions, as I have tried to find answers, and although I have found answers to some of my questions, I have not found answers to all of them.
1) When I store a trunked system or a conventional frequency in one scanlist, and then store some of the talkgroups or conventional frequencies on another scanlist, the talkgroups or frequencies from the first scanlist will not stay in the memory and will be deleted. This seems to be a feature to prevent copying the same data which could be very useful. However, sometimes I want to keep a few frequencies the same over a couple scanlists. Is there a way to disable this feature?
2) Is there a way to have the radio use the spectrum sweeper while actively scanning a scanlist?
3) How do I turn down the audio on P25 phase II which is much louder than Phase I?
4) For some reason the Spectrum Sweeper will not pick up my HT's transmissions on 70cm while it will on 2 meters. (It works on 70cm on another radio) I've turned Zeromatic off and then it picks it up but was wondering if there is a possible explanation or solution to this problem while keeping Zeromatic on?
5) When recording, is there a way to get the radio to display the information Pl tone, Nac, color code, tg, etc. I've read that the radio can do it, but I'm having a hard time finding out how?
6) Also, on the EZ-scan software if I delete conventional objects, I have to click each object. I feel weird asking this, but is there a way to highlight the objects so it speeds the process up?
7) Finally, last but not least, I'm having some more trouble getting the EZ-scan software to display all radio id's for conventional objects. I can edit each object individually via the radio, but even when I go to the software and select what I want for each line it still doesn't work. Could this possibly be taking place because these conventional objects were programmed before I edited via EZ-scan?
Quick edit, I see an auto power on feature. Is there an auto power off?
Any help would be greatly appreciated.
