and how does this affect the monitoring of NXDN
As is always the case.... it depends.
There are a lot of different types of NXDN systems out there. On most systems, it works just fine.
From my experience, there are two things that will impact performance more than in other cases:
- if the trunked system "aggressively" changes frequencies between voice calls on the same talkgroup (i.e. responses), you can miss a lot of responses - particularly short responses like "10-4" or other one or two word messages.
- the other would be if they system/site has a large number of frequencies (which can also make the above worse)
Other things to consider include multi-site.... unlike other systems like P25, you'll only want to enable the closest site(s).
Also, from what I've seen, there are some larger NXDN systems that are simply a total mess when it comes to what we know about them.... and this can impact performance as well. I have a site for a multi state/site system near me that doesn't even seem to have a valid active licence which complicates things even further.
On the other hand, since no other scanner does NXDN, I'll stick my neck out and say it does NXDN better than any otger....
