It seems like my TRX-1 is experiencing some kind of skipping behavior when I do a limit search. Let's say I am searching on the 850-860 MHz for trunked system, the scanner will pause on where signal is present (confirmed using PSR800 and it is a very strong control channel), pauses momentarily, then continues scanning without unmuting. When I pause the limit search on the control channel and turn the squelch way down, the scanner will continue stay muted.
If I scan the trunked system as a normal object, the scanner unmutes on talk group just fine, same with conventional channel, though the scanner seems to be a little bit on the deaf side as compared to my PSR-800.
Has anyone experienced this problem as well? this is getting frustrating.
