johnwashington
Questions if I may:
1. When I turn off the scanner the display says "power off" and the screen darkens. 3 seconds late, the screen brightens and displays the time, date, and day and stays on till I press the "on" button then it commences to load data. If I want the screen to completely darken I have to unplug the power. Is this normal?
2. Using the EZ software I select what system to listen to. I do not select "Transportation , Utilities, public works, but they are in the list of systems being scanned.
3. Is there a way to permanently lockout frequencies brought up via the front of the scanner. I know you can skip but I believe this is just temporary.
Thanks heaps
John
Thanks heaps
John
