easternshore
hello guys, went to re format my 1095 with out checking all three boxs in ez scan / computer is sying i need to format the disk in drive E before it can be used, im thinking i may have to pull sd card out , put it in a card reader to the pc then do the re formating to the sd card from ez scan then put card back in scanner and start over, only thing im getting with either scanner pluged to power or with out power with usb cable to pc without power is a errow message which is 3-04, hoping someone has been down this road that can help me, best regards easternshore, thanks
