I just got a WS1040 and I'm having a hard time programming this thing.Needing to some how download the frequencies into my scanner from the programming usb cable. But not sure how to do it.
I'm in Indianapolis ,Indiana and want all of the Indianapolis Fire Dept primary and ops channels only.Is this possible ?
It would appear, based upon the RR Database, that the Indianapolis Fire Dept uses a Project 25 Phase I trunked radio system (TRS).
https://www.radioreference.com/apps/db/?sid=5737
I believe that the WS 1040 is suitable for monitoring that type of TRS.
I am only familiar with the Win500 software as it relates to Project 25 Phase I TRSs. If you are using different software or no software, I can't help you.
When using Win500 software (or any suitable software), the proper terminology might resemble:
1) Import TRS/s into the software (using the software).
2) Assign/Distribute Talk Groups (TGs) into the numbered Scan Lists of your choice (no cable or computer needed for 1) and 2))
3) Upload the Scan Lists into the scanner (cable required).
Oh, by the way, welcome to the RR Forums!!!
