Old 02-01-2018, 4:35 PM
Default WS1040
Does anyone else have this issue with the ws1040. When using AC power, I'm not picking up radio traffic as well as when I use the battery power. Im not sure if it's the radio or if this is a normal thing. Whistler has no idea. Thanks.
Old 02-01-2018, 4:47 PM
jasonhouk's Avatar
When powering through batteries oper the squelch on an analog weather channel then plug the unit in. My best guess is there's a lot of noise coming from the power adapter.
J
Sent from my Moto G (4) using Tapatalk
Old 02-01-2018, 6:52 PM
Thanks I will try that. I was also told to wrap the power cord around a large nut. That didn't help.
Old 02-02-2018, 5:42 PM
DJ11DLN's Avatar
I have a Pro-651, essentially the same radio, running on a cheapest-of-the-cheap power supply from Menard's...it works fine. Follow the advice above to diagnose the problem, you must have a really horribly noisy power supply.
If it looks stupid but it works...it ain't stupid.
Old 02-04-2018, 12:13 PM
Thanks, I have another AC power cord, I will try that.
