  #41 (permalink)
Old 02-07-2018, 11:06 AM
Originally Posted by kc5igh View Post
Thanks!
Should I first uninstall the current version of EZ Scan on my computer?
If I do that, I suspect it means I'll then have to download the stored contents of my TRX-1. Is that correct?
I just installed it without un-installing the old version. Worked fine for me.
  #42 (permalink)
Old 02-07-2018, 11:30 AM
Thanks!
I'll give it a try right now.
  #43 (permalink)
Old 02-07-2018, 11:31 AM
I'm running Windows 10 Pro on a Surface Pro 4 with a screen resolution of 2736 x 1824 and also have the issue of scaling/missing text. My fix was to right click on the executable, click on Properties, click on Compatibility, check "Override high DPI scaling behavior.", then select "System". This fixed the display issue for me.
I also noticed this new version takes a while to load once selected, much longer than before. I'm running a 6th generation i5 processor with 8 GB of RAM, so not the slowest out there.
  #44 (permalink)
Old 02-07-2018, 11:45 AM
The download was blocked at first by my web security program (Trend Micro Internet Security), but it seemed to proceed very quickly once I got past the warnings.
I checked for updates after the download was completed and was told I have the latest version available.
I haven't needed to update anything lately, so I'll see how all this works if/when I do.
Thanks for the help!
-Johnnie
  #45 (permalink)
Old 02-07-2018, 1:00 PM
Default Down load
Why do we have to pretend to buy it?
I guess it is one way of acquiring a customer data base.
Seems uncomfortable.
  #46 (permalink)
Old 02-07-2018, 1:14 PM
Default Please check!
Please! Who wrote that "New EZscan works fine..." - please say how looks the screen ? In my case i cant see the right Edit Bar nor scrolling bar
  #47 (permalink)
Old 02-07-2018, 1:18 PM
WhistlerWendy's Avatar
Whistler Representative
We are looking into some compatibility issues with some Win 10 operating systems and will have a universal fix after it has been tested on more PCs In the meantime please follow the steps below and it should correct many of the issues that have been reported with Win 10.
Right click on the shortcut and select Properties > Compatibility > and under settings check the box for Override high DPI scaling behavior, then select System in the drop down box and hit Apply.
  #48 (permalink)
Old 02-07-2018, 1:24 PM
Originally Posted by WhistlerWendy View Post
...Right click on the shortcut and select Properties > Compatibility > and under settings check the box for Override high DPI scaling behavior, then select System in the drop down box and hit Apply.
No any changes on my Win7 PC...
  #49 (permalink)
Old 02-07-2018, 1:50 PM
spanner's Avatar
Thank you, that brought the buttons for me!
Carl
WL7AF (Falls Church, Va)
GRE 500
BC 780XLT
BC 245XLT
PRO 96
PRO 2006
FT 857D
FT 530
"Get in the car, were going on a GUILT trip!"
  #50 (permalink)
Old 02-07-2018, 2:31 PM
Hi Wendy,
What about all the antivirus hits a lot of people are getting?
  #51 (permalink)
Old 02-07-2018, 2:33 PM
-Johnnie
You are welcome.
  #52 (permalink)
Old 02-07-2018, 8:20 PM
Having defender on Win 10 pro flag on the TRX-2 installer now, submitted it to MS for review and hopefully it will be seen it is a false positive.
VIrusTotal shows only 1-2 detections for each (well within false positive range but not knowing MS, because according to its review page it was only hitting on the cloud and not in the client).
Other then this and the bug i posted about on page 1 everything works fine.
Ham stuff Icom 80AD, Icom 208H
Scanners: TRX-1, TRX-2 Antenna: ST-2
  #53 (permalink)
Old 02-07-2018, 8:33 PM
frazmandemo's Avatar
well i installed the update and have had no problems since.
ws 1088 pro-97 bc350a
the more idiots break the law, the more money I make!
  #54 (permalink)
Old 02-07-2018, 8:49 PM
tumegpc's Avatar
Good to go on Windows 7 64bit.
TRX-1 ~ TRX-2
436HP ~ 536HP
  #55 (permalink)
Old 02-07-2018, 10:48 PM
hiegtx's Avatar
Mentor
Same here.
Steve
  #56 (permalink)
Old 02-07-2018, 11:11 PM
lanemls's Avatar
2/6/2018
Hi everyone -
Due to the change in SSL versions, please update your EZ-Scan software with this newest version.
Once you have downloaded and installed this version of EZ-Scan, all server based updates should work correctly.
All updates are available here -> https://whistlergroup.com/pages/downloads
Thank you for your patience.
Thanks,
Whistler Wendy
Just installed the update on both of my computers. ALL good to go! Thank you very much.
  #57 (permalink)
Old 02-08-2018, 12:06 AM
MS Reviewed the TRX-2 installer that was being detcted by defender, no malware detected so i guess next definitions it should not hit it.
  #58 (permalink)
Old 02-08-2018, 12:33 PM
Good! Now updated WS1095/WS1098 v.2.31 WORKS just fine! Thanks Wendy, thanks Whistler!
  #59 (permalink)
Old 02-10-2018, 8:21 AM
Really silly way to make us download this...
  #60 (permalink)
Old 02-10-2018, 1:53 PM
Jumped through the hoops to download, been getting this for over an hour: "Waiting for response from transactions:sendowl.com"
BCD436HP and Whistler TRX-1 (current workhorses)
Pro106 (semi-retired for potentiometer preservation)
Pro96 (still useful)
AOR DV1 (Bodacious rig)
Tags
trojan malicious code, trojan virus
