Old 02-06-2018, 12:08 PM
WhistlerWendy's Avatar
Whistler Representative
Thumbs up 2/6/18 - EZ Scan Update - EOF Error fix
2/6/2018
Hi everyone -
Due to the change in SSL versions, please update your EZ-Scan software with this newest version.
Once you have downloaded and installed this version of EZ-Scan, all server based updates should work correctly.
All updates are available here -> https://whistlergroup.com/pages/downloads
Thank you for your patience.
Thanks,
Whistler Wendy
Old 02-06-2018, 12:24 PM
GlacierClipper's Avatar
Location: West of the Muddy Creek, East of the Big Hill.
Thumbs up
Works great!
Not issues on the updates today!
Waiting is sometimes a reward!
GlacierClipper
Old 02-06-2018, 12:41 PM
Default Whistler update
Thanks for fixing this. Works fine now. Downloaded new EZ-Scan software, uninstalled software on PC and reinstalled with new software (all programming stayed). Thanks
Old 02-06-2018, 1:12 PM
zwc's Avatar
zwc zwc is offline
awesome. I will download this once I get home. Cheers!
Old 02-06-2018, 1:15 PM
I installed the new version with no problem but Avast antivirus blocked it from running as an unknown suspicious file. I indicated it was a trusted file and Avast acknowledged the report but still refuses to run it.
I temporarily disabled Avast and the file runs fine. Hopefully, Avast will do an update to allow it to run. Other Avast users may have a problem unitll this is resolved.
Old 02-06-2018, 1:44 PM
Seems to be a glitch if i try to mass select in the scanlist to change delay or led settings, once i set it and come back to the list it clears all trunked systems Alpha tags and scanlist number. And also it is adding conv freqs alpha tag's first letter only not and not the whole alpha tag.
Icom 80AD, Icom 208H
TRX-1, TRX-2
Old 02-06-2018, 2:27 PM
03msc's Avatar
Someone else recently reported that Norton was flagging it as a trojan virus on their machine...not sure what's going on. Since you know it's from Whistler just turn off Avast while you install and then turn it back on...
Wendy - can you make sure the devs know about this and see if they can figure out what's tripping these AV programs?
Mark Arkansas K D 5 B V X
Uniden and Whistler Scanners Kenwood and Yaesu Radios
Old 02-06-2018, 2:48 PM
Tried to download the TRX-1 program using Windows Internet Explorer. I got all of the way to the Download screen. Clicked on Download, nothing happened.
So I tried Chrome, this time the Download started and was halted with a Windows Defender error message. But, it did let me continue. I then received a Norton AV message indicating it was an unsigned file. I was given several options. I selected to continue. I was then prompted to recommend a rating, I selected Safe for download. At that point the download proceeded and I was able to do the install.
Wow, talk about jumping through hoops.
Bud
Pro-34/Pro-97/PSR-500/BCD436HP/TRX-1
Old 02-06-2018, 5:18 PM
Default trouble v-scanner folder description
I don't seem to be able to set v-scanner folder description after todays (2-6-18) software updates on both TRX-1 and WS1098. Everything else looks fine so far..
Old 02-06-2018, 5:32 PM
davidzimmerman's Avatar
got both EZscans in my Emails download all done for my TRX-2 and 1080
kbod9633's Avatar
Originally Posted by WhistlerWendy View Post
2/6/2018
Hi everyone -
Thanks,
Whistler Wendy
how do we resize the fields? mine are all crunched together with this new version
a couple of them can be resized but others cant and you cant read anything
Bob
BCD536HP, BCD436HP, BCD996XT, 2 TRX-1's , PRO-96
Old 02-06-2018, 5:40 PM
I don't see the right editting panels at "Scanlist" "Conventional Frequencies" and "Trunked Radio Systems" sections. Where now are buttons New, Duplicate, Delete? Where is Import from clipboard?
Old 02-06-2018, 6:10 PM
buddrousa's Avatar
Change screen sizes.
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP BCD536HPx2 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 Tk280 TK2180 MD380x4 NX5300 NX5200 Buddy
Old 02-06-2018, 6:11 PM
w8nyy's Avatar
Same issue here. Whistler Support is saying "We are looking into this. It seems some Win 10 systems but not all are experiencing this issue."
Old 02-06-2018, 6:14 PM
kbod9633's Avatar
nope
Bob
Old 02-06-2018, 6:22 PM
spanner's Avatar
Cannot or cannot see where the "import audio" is now.
WL7AF (Falls Church, Va)
GRE 500
BC 780XLT
BC 245XLT
PRO 96
PRO 2006
FT 857D
FT 530
"Get in the car, were going on a GUILT trip!"
Old 02-06-2018, 6:49 PM
nosoup4u's Avatar
I have 2 Windows 10 machines and both are messed up after this update. I even tried to uninstall and install fresh and the screen is still screwed up.
John - KC2KZZ
http://www.warrenskywarn.org
BCD536HP, BCD436HP, Home Patrol-2 , BC125AT, TRX-1 and other old crap.
@kc2kzz - My Twitter feed. @WCAlerts - Warren County Fire/EMS alerts
Old 02-06-2018, 7:06 PM
Ed6698's Avatar
Updated EZScan for my WS1080 and 1095 on Windows 10, everything appears to be working fine so far.
WS1080 WS1095 PSR500 PRO95 BC200XLT x2
Old 02-06-2018, 7:19 PM
What is your screen resolution set to?
Old 02-06-2018, 7:30 PM
Everything working correctly on my Win 7
Tags
trojan malicious code, trojan virus
