K2RNI
I just got some Eneloop Pros with my WS1040. I already switched the setting to NIMH and put them in the yellow holder but notice there is also a charge time setting below. What is this for and do I need to change it?
Does the scanner stop charging when it detects certain voltage or is it a timer based charging circuit? Because I notice it is capable of reading the voltage precisely when you go to the battery info section of the menu.
