racingfan360
- Joined
- Dec 19, 2005
- Messages
- 1,158
Is anyone else now having issues with EzScan v3.23 connecting to your scanner? I've never had any problems up until now...the scanner appears as if it isn't connected (via USB), so I can't undertake any firmware updates. However I can still complete config updates to and from the scanner after a few (usually 3) attempts.
Just to confirm:
- I have tried both the signed Windows driver and the Whistler driver (as discussed here: https://forums.radioreference.com/whistler-scanners/317662-whistler-scanners-windows-10-a.html)
- I've tried the same scanner and usb cable on a separate laptop. This is running the default signed Windows driver, and it works ok.
- both devices running Windows 10 Home on the latest updates
- I've even tried different SD cards but with the same results
- I've tried re-installing EzScan several times
Any ideas?
TIA,
Jim
Just to confirm:
Any ideas?
TIA,
Jim
