I was told best way to program your scanner is download everything and stead of breaking sites up into different scan lists then toggle the different talk groups on and off depending on what you want to listen to. What is the easiest way to shut off and urn on talk groups? I planed on shutting and turning on different scan lists.
Who ever told you that has no clue what they are talking about!
First off the WS-1065 has a memory limitation of 1852 objects. By downloading "everything" you will max out the scanner's memory. Not knowing what area you are from I can't advise you on what system(s) you are referring too but if they are large you will fill up the scanner with worthless objects. Refer to your manual to read up on Objects and what comprises objects for your scanner
Also, your scanner is limited to 20 Scanlists. you need to pre-think what you want and wisely assign scanlists. There are numerous methods you can use depending again on where you are listening. Some people set up Scanlists by County, some by type, i.e. police, fire, ems, etc.
Trying to enable/disable Talkgroups is not a very efficient or quick way to control your scanner.
Best way is -
1. Setup Scanlist in such a way to just have to toggle on/off by pressing keypad numbers.
2. Use the "Favorites" option to carve out those Talkgroups you would like to listen to in certain situations. Then with one keypad button push you can switch to Favorites and not hear all other Scanlists.
