WerewolfOne
I received a Whistler 1098 today as a gift. Other then an issue with "Error Code 4.00" which was quickly rectified with advice found on Radio Reference.com I got it out and set up without a great deal of difficulty.
1) However, I can't hear anything with it. The antenna is hooked up securely (it picks up the weather o.k) but nothing else. Set it up using the quick start guide, entered the state, county and agencies I wanted to listen to, set up then selected a scan list, it started to scan. Nothing.
2) I then tried entering my zip code and it loaded EVERYTHING in my area (Grand Traverse County). Still nothing. Any ideas how I get rid of that???
Anyway, I've had analog scanners in the past, so thought I was reasonably savvy with how to set this up. The chances are it's something simple I'm not doing. Can any of you folks help???
Best Regards
Joe D
Best Regards
Joe D
