devicelab
Whacker Extraordinaire
So the last two times my TRX1 has done the following:
Unit is plugged into AC power strip (with USB port) and plugged into the scanner full-time. Scanner is actively scanning a couple of scanlists. After a period of time, I check the TRX for its recordings. If I see something juicy then I power off the unit and then plug it into the computer and read its recording data and go from there.
When I'm finished I unplug the scanner and plug it back into the AC power strip; however, the last two times, I go to power on the TRX and the display is blank. Nothing. Short or long power button press does nothing. Unplug USB cable. Power button does nothing. Plug back into computer does nothing -- the USB chime doesn't sound and the PC doesn't see the scanner as usual; however, when I pull the USB cable the disconnect chime does sound.
Only after I lift & seat one of the rechargeable batteries (i.e. remove it from power source) does the scanner power on. (I've powered on thru power button the first time and today when I plugged the USB cable back into the AC strip -- the clock was displayed on the TRX LCD screen.)
I'm using (4) PowerEx 2700mah batteries in my TRX. My EZSCAN Advanced Battery settings are all default.
Any ideas?
Any ideas?
