This problem has really got me stumped. Recently one of the casinos on the coast here switched from conventional to Hytera XPT. Here is a link to the FCC license info:
ULS License - Industrial/Business Pool, Trunked License - WPHV318 - GRAND CASINO HOTEL BILOXI - Frequencies Summary
I found out that 5 frequencies are activem and programmed them in conventionally and in a MotoTrbo Trunk network on my 436 and also programmed them into my TRX-1 in a DMR system. I was several blocks away from the site today (at another casino) and had both scanners monitoring it at the same time for several hours. When I got home, I reviewed the results and found that on the 436 Mototrbo trunk it picked up nothing (expected because no LCN's are entered yet), and the conventional gave me several talkgroups (Numbers from 3-13).
Then I reviewed the TRX-1 and it gave me talkgroup numbers from 4194307 through 4194315. The User ID numbers for both radios were the same, in the 1100-1300 range.
Is the reason for the difference because of the way I programmed them, or does each radio handle the talkgroups in a different way? This is the first system that was different between different scanners. Any help would be appreciated. Thanks!
