masonjessical01
- Joined
- Aug 9, 2018
- Messages
- 1
Struggling with my new ws1065. I finally thought it was programmed downloaded it to scanner and now it says nothing is enabled??? Please help me this scanner is driving me crazy.
A common problem with those scanners is the frequencies are in fact downloaded to the scanner but the scan lists are not enabled. Another common problem with those scanners is they are downloaded but not assigned to a scan list. Without knowing exactly what you're trying to download and to where you're assigning stuff, I'm afraid that will be about as far as anyone will be able to help you. Feel free to shoot me a message with what you're trying to do and I'll see if I can help you.Struggling with my new ws1065. I finally thought it was programmed downloaded it to scanner and now it says nothing is enabled??? Please help me this scanner is driving me crazy.
To take advantage of the premium subscription you need a programming app. You have your choice of Win500, ARC500, or PSREdit. All have 30-day free trials so you can test drive before you buy. You need a programming cable too.my mom bought a ws1065, i'm trying to program it, the directions for this stinks! it tells me nothing enabled, we took the premium package from radio reference.com, that was a disappointment. what do I do before i throw it out the door?
Yes you need an enabled subscription, and an app .It looks like you already have that setup.
Make sure you have your ScanSETs and ScanLists enabled.
Make each town a LIST
Put all your LISTs in 1 ScanSET ,enable it.
If that bombs you can always ask one of us to program a file for you.
Don't give up, you got this far!
Going to jump in here. I have downloaded win500 and have gotten the frequencies that I want. Uploaded them to the scanner, made sure everything was enabled (turned on/whatever). All lists were selected, but I am still getting nothing enabled on my scanner. I went to update my scanner frequencies and lost everything. Have tried to upload to the scanner 3 times. What am I doing wrong.
"Nothing enabled" meas you don't have a scan list selected. When you see "Nothing enabled" on the display, press "1" on the keypad to enable the first scan list. What happens?
The heap error usually means that you have a talkgroup not assigned to a system. I feel your pain, when I first got back into scanning several years back after a longer hiatus, I about tore what is left of my hair out as well. But it sounds like starting over from scratch is going to be necessary. Remember, select system, then select sites, then select talkgroups, in that order.
So do I have to have a site and a talk group? I'm about to pull the rest of my hair out too.
Yes. Select the system you want, Win500 will import the whole thing but don't sweat it, the scanner will only try to monitor what you select. Next select the sites close enough for you to receive. Then select the talkgroups you want. Then upload to the scanner and see if it clicks this time.
Thanks so much. I'll let you know how it works out. These are so different from what I use to have so many years ago
