No, EZScan is the software on your comp. Go there. You will see the Update tab/selection there at the top. Then after updating, you write it to the scanner itself. You'll also see a variety of updates - CPU/Firmware/Database, might as well update them all while you have the scanner plugged in.
JD
kf4anc
