Is there anyone out there that can possibly walk me through the process of entering a talk groups in a ws1065
Usually I use WIN500 for programming, makes it simple. But try the following :
TGRP Menu Scan Lists – Press SEL to assign the object to scan lists. An asterisk (*) indicates an assigned scan list. TSYS – Select or define a TSYS object. ID – Digital address for the talkgroup or individual radio (Wildcard, Decimal, hex or AFS, depending on TSYS type) Wildcard monitors all talkgroup call traffic on the associated system Type – Group = Talkgroup ID; Private = individual radio ID. Tag – The display name for the object. L/Out – Permanent lockout status for the object. Priority – On or off. LED Mode – Solid or Flash. LED Color – 0=Off, 1=Red, 2=Yellow, 3=Green, 4=Cyan, 5=Blue, 6=Magenta, 7=White. Latch LED – Off, the Alert LED is active only while the object is receiving a transmission; On, the Alert LED will remain lit after the transmission is complete, unless overridden. Backlight – On, Off, or Flash. Alarm – None, Chirp, Hi-Lo, Alert, Ring, 2-Chirp, Fast Hi-Lo, DTMF#. Fav – Assigns the object to the Favorites scan list. Skywarn – Assigns the object to the Skywarn Scan List. Delay – On or off. Delay Time – (1-250) Delay time in 100 ms. AudioBoost – 6 dB audio level boost. Hit Count – Number of received transmissions for the object. Global Hit Counts must be set to on. Press the Dflt softkey to reset to 0.
Sent from my LG-Q710AL using Tapatalk
