babyredwing
I have been trying to program channels into my scanner the TRX-1 and can not get it to work..
If someone can help me that would be great.. I am really new to all of this and trying to understand.. What I want to get is my local fire deptments and ambulance channels and they are not listed in the ez-scan software.
I will start with my local fire department. St. Remy Fire District Ulster Park New York Call sign WQWR 743
.Found a couple of Frequencies listed.. One in a white column and one in the Blue or highlighted ( the same frequencey number ).
I entered the frequencey number under new channel added it in and after that Heck I got lost since it never worked guessing at all the questions..
The software asks questions I can not find answers to and do not how to find the answers to the questions in radiorefrence.
The fire department and ambulance group is only 3 houses away so I know that they are not to far way to receive. I do believe they are conventional frequencies.
If someone could take a little time and walk me throu the proceedure and how to use the Radiorefrence info on to program the Trx-1 So I can get the my local stations wold be a very big help.
I am 68 yrs old and not very tech savy and been trying to figure this out now for a couple of months with no luck.
I did purchased the scanner pre programmed knowing I would have issues with programming but they only installed what was in the ez-scan libary and nothing else.
It seems to be a very good scanner and for what is programed into it I will say it works very well Just adding to the library is not easy for me. ..
