scosgt
- Joined
- Jul 22, 2004
- Messages
- 1,295
Has anyone seen anything like this before?
Had it in my car. Ran for a few minutes. Turned it off from the switch.\
Turned the car back on to turn the radio on.
DEAD.
After many button pushes, turned the car off and on again. Came up with the clock and worked.
Arrived home. Plugged into the AC adaper, worked fine.
Decided to use a different outlet. Turned off normally, pulled adapter and moved, DEAD. Button push did nothing.
Unplugged the AC. Plugged back in. DEAD
Pulled the plug from the back, came right on normally.
Anyone seen this before? AC is good,
DC is good, plug in back has to be good because in the car I did not disturb it.
the only thing in common is that each time it was without power for a very short time, under a minute.
Any ideas?
DEAD.
Any ideas?
