Thanks for the thoughtful and interesting idea, and I see your point.
A brief comment, so that I don't go too far OT and duplicate the conversation in the other thread that is in the DB forum...
This is DB suggestion, but relevant to this discussion. How about adding a checkbox to the Submit function that says, "Update requires change to Wiki"?
I think there might be a weak spot here, though, in that the existence of the check box in the DB-submission form:
- (1) would infer that the person making the DB-submission, also:
- (A) has a valid working understanding of the Wiki, and
- (B) has verified whether or not a Wiki-change is needed;
and
- (2) that when unchecked, the box would be interpreted by the DBA as "submitter verified that Wiki action is NOT needed"
instead of "submitter is unsure that a Wiki action is needed and therefore did not check the box".
and
- (3) would not alert as many Wiki knowledgeable people as posting a message in the Wiki forum does, like this thread did.
and
- (4) might cause the DBA to forget that he/she needs to check the Wiki anyway because a Wiki-change might have happened between the time the DB-submission (with the unchecked box) was submitted, and the time the DBA handled the DB-submission. (In the cases where that gap is days-long, many Wiki edits can happen, including ones related to the DB submission, whether those Wiki-changes were coordinated or uncoordinated with the DB-submission.)
From many posts in the forums, I believe that many people
- do not use the Wiki,
- are unsure what is in the Wiki,
- are less-than-comfortable with navigating the Wiki,
- and in some cases, publicly admit that they have abandoned the Wiki because what they contributed to it was later changed by someone else to their dissatisfaction.
Statistically speaking, I don't think we can assume that every person who submits data to the DB will check the Wiki, and even if they do check the Wiki, will notice every single thing that might need to be updated in relation to their DB submission..
I applaud anyone who does or would make the effort to ensure the Wiki is correct, as part of their process for submitting data to the DB Team, whether that involves starting a thread like this one to report a Wiki-change that is needed, or whether they make the change themselves.
But, I believe that someone who is comfortable editing the Wiki will need to review the Wiki in relation to DB-page name-changes, etc. because
- (1) every name-change in the DB effects the Wiki, or could
- (2) some of the nuances, and "hidden" elements, of Wiki-editing are not "obvious" until someone has spent sufficient time editing the Wiki, including REDIRECT pages and how to determine whether they should be kept or dropped, and the Templates that are used.
Thanks for the idea. It is an interesting one.
Hope this helps,
