I remember seeing an example of this but can't find it.
Say I have a 60 line entry in a table in the wiki but would like to make three columns across the page of 20 lines each.
How do I do that?
Another solution for side-by-side layout is to use nested-tables. Basically, an outer-table with its border hidden is used to create the columns, and each of its unbordered-columns contains a stand-alone inner-table with borders visible.
The first three sections of
Parma / Medina County / Ottawa County (P25) RID/UIDs have been reformatted using this technique.
There are HTML-comments in the page's Wiki-code to help clarify. HTML code was used to create the outer table just to make it obvious which table was outer and which was inner. The outer table could be created using Wiki-syntax, but some Wiki-editors might find that confusing.
If you would like to reformat the remainder of the page, you can follow those examples. If you want to revert back to the previous formatting, you can click the page's "History" button and undo the related changes.
Hope this helps,
