Need some help, I am looking at buying either a HP 1 or 2 what is the main difference between the two other then the touch screen?
I am in Polk County, WI and the only Counties I am concerned with is Polk County, Burnet County WI and Chisago County in MN.
I have a 996P2 but it is kicking my butt also this darn computer does not have com ports why ??? and I know do jack about computors ther then the on off button.
The 996P2 does not need a serial port. You can do everything you need, programming as well as any firmware updates, through the mini-USB port on the front panel. You do, however, need to install the serial driver so that you can use the supplied cable. The driver can be found on this Uniden page.I am in Polk County, WI and the only Counties I am concerned with is Polk County, Burnet County WI and Chisago County in MN.
That's correct.HP-1 uses the older power supply wall wart..I think the HP-2 uses the USB to charge and power
If you still have the 996P2, that can do what you are saying you want, as long as it is correctly programmed. What you may want to do is to ask that your post be moved to your state forum, and then ask there if someone in your vicinity can set up a file for you. If you have (or can install) software on your computer (FreeSCAN is available, and as the name implies, is free), then any number of other users could put together a file for you. That would be less costly than buying another scanner, though, of course, if you sold the 996, that would offset it some.Holy Cow Burp you need to be a 600 IQ to take in all of this information, my brain is already starting to smolder,, I really do not need a scanner with more than say 20 channels as I am quite rural the closet major city is Minneapolis and that is 70 miles away, Burnet County WI. is 30 miles and Chisago County, MN is 10 miles, my only real interest is Sheriff, Fire and Ambulance. The other factor I am looking at is price as I am now on a pension (retired)
If you folks can point me in the right direction I thank you
Jim
If you have not done so, download Sentinel and install it on your PC. The link is near the top of this page. Down near the bottom of the page is the serial driver, which needs to be installed. However, if you installed the serial driver for your 996P2, you're good to go. Once Sentinel is installed, update the database in the software (click on the Update drop down menu, and select Update Master Database. Once you've done that, set your location in Sentinel and choose a range and service types to monitor. More about how the range setting works can be found here.Well I picked up a used Home Patrol 2 on Ebay for $275.00 and if it works as they say it is supposed to by inputting my zip that will be swell I have to thank all of you for your support and have a very special 4th of July
Jim
