Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Wyoming Radio Discussion Forum
Wyoming Radio Discussion Forum - Forum for discussing Radio Information in the State of Wyoming.
  #321 (permalink)
Old 12-30-2016, 9:18 AM
Thank you, W7LES for this insight!
W
Wally Bloss, WB0BAV
HTTP//www.wallybloss.com
A Human
  #322 (permalink)
Old 08-19-2017, 10:11 PM
n8zuz's Avatar
Default Thank you to all of you who have figured this out
Thanks to everyone in this thread who has made the database what it is. I just moved here and programmed my old Uniden BCD396T and all is working.
I was surprised to get good signal strength as I am in Lagrange in Goshen County and Lagrange is in a bit of an RF hole as it's in a low spot geographically.
  #323 (permalink)
Old 08-20-2017, 9:19 AM
That area seems to have pretty good coverage. Between the 77 Hill, Torrington, and Whitcomb sites, you should have a good time listening around there.
Glad it is working out!!
WM
EMT Paramedic,
  #324 (permalink)
Old 10-17-2017, 9:28 AM
GOLDENDOME's Avatar
Can anyone tell me the band plan for wyolink using a Uniden scanner, it requires trunking table.
Any help would be great.
  #325 (permalink)
Old 10-18-2017, 8:25 PM
ID / Low Channel / High Channel / Channel Offset / Base Frequency / # of Slots / kHz Step / MHz Offset / kHz Bandwidth
00 / 0 / 4095 / 0 / 851.00625 / 1 / 6.25 / -45.0 / 12.5
01 / 4096 / 8191 / 4096 / 762.00625 / 1 / 6.25 / 30.0 / 12.5
02 / 8192 / 12287 / 8192 / 150.9925 / 1 / 2.5 / * / 12.5
03 / 12288 / 16383 / 12288 / 146.7775 / 1 / 5.0 / * / 12.5
04 / 16384 / 20479 / 16384 / 146.775 / 1 / 5.0 / * / 12.5
05 / 20480 / 24575 / 20480 / 153.5275 / 1 / 5.0 / * / 12.5
06 / 24576 / 28671 / 24576 / 149.37 / 1 / 5.0 / * / 12.5
07 / 28672 / 32767 / 28672 / 136.0 / 1 / 12.5 / * / 12.5
* = determined by control channel
  #326 (permalink)
Old 10-19-2017, 10:27 AM
GOLDENDOME's Avatar
Smile
Thank you
  #327 (permalink)
Old 09-01-2018, 10:03 PM
For thosewho do not know, the channel for Mountain View Hospital ER is no good. The hospital was bought and the ER was closed.
KE7WQP
Michael
  #328 (permalink)
Old 09-01-2018, 10:18 PM
PJH's Avatar
PJH PJH is offline
Global Database Admin
What county is it listed under, and no traffic of any kind is on that talkgroups, correct?
If you have received a PM from me about a submission, kindly reply within 5 days with requested information or your submission may be rejected. Thanks!
  #329 (permalink)
Old 09-01-2018, 10:27 PM
There will be no more traffic there, correct. And the talk group is under natrona county.
Tags
sticky
