DMR Color Code scanning
thundermedic
Database Administrator
Calgary, Alberta
There are a few users in my area using DMR systems and I just bought a brand new MD-380
I did install the jailbroken firmware, but the one thing I found with it is it won't tell you what talk group is in use, or give you any information for scanning in the future. Because of this, and the fact that I use it for amateur radio I had to put the original firmware back on.
What is the easiest way to determine colour code to monitor or to talk to other Symplex DMR users?
RayAir
It's best to use DSD+ or DMR Decode to get the information you need if it can't be found in a data base. Even if it is in the db it is best to verify it yourself.
I monitor quite a few DMR systems and many simply use color code 1.
Voyager
It costs more, but that's what I love about the CSI CS-750. It will show the color code, TGID, RID, and slot number of any DMR user.
RayAir
If it only worked while scanning it would be so much better.
Supposedly CS will have a multi-mode out with open firmware in the next year....supposedly.
jtech48
OVB
I agree, even though you cant use the monitor mode while scanning you can easily figure out the info you need to add a new channel with that information or at least compile a list
Voyager
Yes, it would. And if only the firmware writers would leave the scan flag set to the current state rather than revert when changing channels, that would be even better yet.
I'm expecting to see the CS7000 in prototype at Dayton.
thundermedic
Calgary, Alberta
If you happen to own a Uniden 436HP or 536HP scanner, Uniden recently announced a firmware-based DMR upgrade that appears to provide such information when monitoring a DMR frequency.
John AC4JK
Good timing on the question eh? Whistler is releasing one too.
