Macon/bibb
mjbjr
Macon,Ga USA
Did they change something again? All was working well,now im getting emails of no audio and not much on some of the archives i pull.
RRR
OFFLINE
USA
I was in Macon today, and didn't hear a peep out of it either.
Wonder if the radio system tech for them reads these posts?
...errr, I mean "wow, sure worked great today!" ;)
troymail
Silent Key
Sounds like they are switching to/using a control channel frequency in rotation that is not yet known. Can someone get a Pro96com dump to see what frequencies they are using.
Just a suggestion.
N8IAA
Fortunately, GA
I have no idea what that means.
What that means is they can change the CC frequency hourly, daily, weekly. You need to program all the site frequencies in so you can follow the traffic.
You just can't sit on the main CC listed in the database anymore.
Larry
mjbjr
Macon,Ga USA
Larry
How am I able to do that?
RRR
OFFLINE
USA
Would unchecking "Control channel only" help?
N8IAA
Fortunately, GA
I changed dispatch to another channel and still nothing. Added a wildcard and found nothingl
Program ALL the frequencies for the system site into the scanner. Adding a Wildcard TGID only allows you to hear NEW TGID's, not frequencies. What radio are you using? Never mind. Saw you are using the 197. Just go into the system frequencies for that trunk system and add them. Click Save and download it to the scanner and see if that helps
Larry
RRR
OFFLINE
USA
