EVX-530 USB cable
WISCOMM
Elm Grove, WI
I had customers contact me to purchase OEM after the "RPC-Y1-UF" did not work for eVerge radios. Works fine on everything other than EVX-530 Series portables.
OEM is the only way to go.
Craig
KA9JYO
Ft Myers, FL
rear connector cable
Craig
I got a plug kit from you, I made a cable from a USB cable, it works intermitent, sometimes loads the driver from the radio, other times the computer don't detect it. I checked the connector pins, they all have continuity
Do you think the problem is in the radio?
Vertex VXD-7200 mobile.
Gashliquor
You been given the answer, But I will repeat it in another way. 99.9% of ALL eVERGE Radios will NOT program with a Joe Smoe's aftermarket programming cable NO matter what that person say's. Get ready to pay.
Craig
Craig is correct. It's a major PITA to acquire the cable too. I had to wait 2-3 weeks for both parts of the cable kit to arrive. I got the base part but had to wait for the radio cable after that.
The Vertex cable kit does work 100% flawlessly. It's worth spending the extra $$$ on the factory cable.
My only regret is that I wish I had bought the mobile rig! ;)
Kf4mnc
OEM or Nothing
I agree with everyone else. Tried the cheap USB cable, provided by a dealer no less, and it did NOT work reliably. Requested the OEM cable for around $100 and it works flawlessly.
KA9JYO
Ft Myers, FL
I used a cheap cable on my Moto xpr 4550 it worked fine, the vertex vxd 7200 is the same radio, but the cable doesn't work reliable.
