Question on BCD536HP Analyze, RTC, 1.06.10
wise871
N.W. Florida
Since no one has posted yet and I can't post under the announcement I figured I ask here.
The new firmware installed great. System Status looks great on the 536. After I updated the firmware I noticed it wiped the time and had to be set. I take it this is normal. Hasn't come up after several starts and figured it was due to firmware upgrade.
Tried out the Analyzer System Status and RF Power Plot. Working great so far. Haven't been able to get EDACS/LTR LCN working yet but that is just my error.
Will x36 Analyzer have Current Activity & Activity Log options later on like the other HP Advanced series?
Will instructions come out on the new features?
Other than the above, working great.
slatescan
Hendersonville,TN
Wise i would be intersted to see a youtube video for the new Analzye options I have a 436hp and i cant wait till it comes out for it too :)
wise871
N.W. Florida
Not much to record since it basically gives me status info only but here is a snapshot of the System Status and RF Plotter.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
It's available in the command set (or at least was prior to this update - I'm not at home where my scanner is, so I can't update it). Look at the Remote Command Plan, particularly pages 28 to 33. You may have to have a decent understanding of XML and the command structure to make it work.
wise871
N.W. Florida
Still no luck with EDACS/LTR LCN. I'll wait until the smart people get home this evening and explain it in simple terms. :)
troymail
Silent Key
Analyze is new to me... what do S, Q, and A represent?
Dan- what is the serial number on your radio (mine is ....1690)? The display sure seems alot brighter and clearer than what I have on mine.... defect?
Jay911
If I recall correctly, S is Signal, Q is Quality (i.e. percentage of trunk messages received), and A is Activity (how busy the system is). Someone with an HP1 would be able to confirm.
bravo14
Polk County FL
I have updated the firmware and I notice the lag on buttons while pressing it took about 3 mints before I turn off the light. The Volume Button setting is off to. I normally have it around 3-4 now I have to have it passed 10 to hear it.
Jay911
I've got my volume on 10, where it was before I updated, and it's the same level as it was before. I'm not finding any lag on any buttons.
ranchboy
TBD
Hi
For the life of me, I can't find upmans post from today, regarding the firmware update! Can somebody post it here?
Thank you
rwier
Phoenix, AZ
I would have answered slightly different, but no different in substance:
Signal Strength
Signal Quality
Signal Activity
I only have the HP-1(E)s for reference, but I would like to see an upper line (color change?) to denote the maximum in each column.. Take the example "grab" posted above, is the top of the "Quality" graph at the max, or at about 90%? 80%?
rwier
Phoenix, AZ
Signal Strength
Signal Quality
Signal Activity
Additional Comment: It is easy to see the "bottom" of the graphs as they all "line up". Even if the tops also all lined up, it could be a coincidence at somewhere less than maximum.
Jay911
I would have thought it reasonable to assume that the top of each bar is 'maximum'. For signal, that'd be 5/5; for quality, that'd be 100% (of packets received/decoded); for activity, that'd be 100% of channels in use.
KevinC
Other
Super Moderator
Home
I "believe" his point was how do we know where the top is?
