Motorola CP185 channel name problem
dixie729
Daviess Co., KY
Re-Programming a 185. All of the channels are named and shown on the cps.
After writing the radio, the names won't show up on the radio screen. All the radio will display is CH 001, CH 002 ext.....
I went through and renamed them all again and wrote it, still the same problem.
Any ideas ?
Sent from my XT1097
OhSixTJ
I think you have to enable the channel name with a button programmed on the radio.
dixie729
Daviess Co., KY
Hmmm. I'll see if I can find that option. Odd that the names were on the radio screen before I read it. I made a couple of frequency and tone changes and renamed one channel and now they are not there.
Sent from my XT1097
gewecke
Banned
Illinois
Any ideas ?
Sent from my XT1097
There are times where channel tags are not a good idea. If someone else takes your radio because you are no longer able to use it..... 73, n9zas
OhSixTJ
But a channel tag is probably more helpful than CH 001.
gewecke
Banned
Illinois
True, But IF it fell into Unauthorized hands then it would be helpful to the Wrong person. I've seen this happen. :wink: 73, n9zas
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
I remeber it being one of the buttons on the side... like holding down the side nipple button and then turning the radio on......that kind of thing.... TT
N1GTL
CT
With older firmware CP185's, when you programmed the radio, it displayed CH###. You had to assign a channel alias button to the radio. When you hit that button, it would switch over to displaying the alias.
With newer firmware, when you program the radio, it will default to the alias without the need to hit a button. I can't recall the firmware version, it changed several years ago.... 3.2 maybe.
dixie729
Daviess Co., KY
I got it guys thanks. I had to program Chanel Alias to a button to display it. Thanks for your help.
Sent from my XT1097
radioguy99
Phoenix, AZ
Firmware version 3.03 will do it and that is the one you need if you want to avoid doing the button feature. There is also a specific software solely for the upgrade.
