signal bar adjustment
i have programed several of the whistler 1040 scanners. i believe the post said you had went to marks scanner and tried the suggestions. did you actually try changing the numbers. i have ran into this you might try the following numbers. bar1=190 bar2=230 bar3=260 bar4=290 bar5=320 it seemed to help on some.if i remember some of the 1040s came with a 2.6 cpu and some came with 2.8 cpu. i dont know if this was part of the problem or if it was something else. these scanners seem a little stingy on the bars showing up, more than on the gre radio shack also gre scanners. the audio and the voice quality is good regardless. one other thing setting the sqelch to about 10 oclock seems to help.hope this heips.squad 1b
